Connect microphones to NI myRIO
I need connect 7 microphones to NI myRIO, it is possible ussing the I/0 analog?
(4,428 Views)
Seems that you only can read two channels at the time.
Hack: Use the two anlog out channels as a synced output to control two analog 4:1 muxer -> 8 inputs
Best case: perfect sync, 100kHz update&samplerate gives you 20kSPS per input  ~> 10kHz bandwidth
so I asume you migth get half of it ...
or use 4 myDAQ 😉
Greetings from Germany
Henrik
LV since v3.1
(4,424 Views)
Thanks Henrik
The idea is good but this problem is that i  need to read  the 7 entries simultaneously, do not want to lose phase.
(4,418 Views)
Than you need a 8 channel simultaneous sampling device.
However you do not loose phase by using multiplexed devices, you just have to do some more math 😉
Henrik
LV since v3.1
(4,388 Views)
Thank your very much.....
Is motivating your help.........I will consider recomendations....see what we can get through this......
(4,363 Views)
