01-15-2014 11:01 AM
I am a student studying for a Beng. As my final project I am looking to create a fault recorder for electrical motors. The basic premise is that it sits and waits for a trip signal, at which point it saves the analogue waveforms of voltage and current for a pre-defined length of time leading up to the trip.
I selected the USB-6009 as the DAQ, mainly based on price. At the time I didn't realise the importance of the pre-trigger (reference trigger) function which the 6009 does not support.
I am sure that there must be a way of using the computer memory to create a buffer using a continuous loop that keeps re-writing to a TDMS file, however I am really struggling to implement this code.
I know the ideal solution would be to use a better suited device, however having already purchased the device and stated it in my project specification this is not possible.
If anyone is able to offer any advice of a possible implementation of this solution and a potential example of a similar program, I would be forever grateful!
Solved! Go to Solution.
01-15-2014 04:34 PM
1. Do continuous acquisition. Keep the data in a circular buffer large enough to store the amount of pre-trigger data you want plus all the post-trigger data which may be acquired before the processing is complete.
2. When the trip signal occurs, either extract the pre-trigger data for stroage or store a marker which tracks where the pre-trigger data starts.
3. After the post-trigger data is acquired, write all the relevant data to the file. Unless you have very long pre- or post-trigger data blocks, TDMS will not be required. The USB-6009 is slow enough that you could keep a few minutes of data in memory before running into memory management problems. That should be much more than you need for a motor fault recorder.
Consider using an Action Engine (search for Ben's Nugget on the topic) for the buffer.
Lynn
01-17-2014 11:04 AM
Dear Lynn,
Many thanks for your quick response, I really appreciate it.
Would it be possible for you to offer me some advice as to how to set up the circular buffer for use with the data aquisition device, I have been trying to experiment with this since your reply and haven't been able to get any results.
Please understand that I am very much a novice to Labview, I undertook the project hoping that I would be able to get a good understanding of the program, however I am fast feeling that I have bitten off more than I can chew!
Thanks for your help.
Ian.
01-17-2014
12:16 PM
- last edited on
06-03-2026
12:21 PM
by
Content Cleaner
A quick search for "LabVIEW circular buffer" found these: Circular buffer using functional globals [link removed; article no longer available] Queue based circular buffer Array as circular buffer and many others.
Lynn
01-19-2014 07:39 AM
Hi Lynn,
Thanks for all your help, having done some reading and playing around i've managed to get to the bottom of the problem, I was confusing myself by not realising that the output of the DAQ device is actually just an N dimensioned array.
Ian.
