Continuesly data collect on 9229
I am using the USB casing with 9229, no matter how long I set to the data length to collect, I can only get <250 points in the acquisition loop in the attached vi. Any suggestion?
(3,029 Views)
Hi Turbot,
Thanks for the post and I hope your well today.
I have no forgotten about the post you've made here: Does the polling fast enough.
Please don't post multiple times for the same issue. I will continue to support you in the main thread.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,025 Views)
