Hello, I was wondering if anyone has some advice about how to setup a continuity test using an M Series PCI 6221 DAQ and Labview 7.1. Specifically, I want to preform a testing regime similar to the IPC-SM-785 guidelines during thermo-cycling of the test vehicles. For those not familar with the guidelines, the purpose is to monitor the resistance of channels that have a DC (10V max.) current (2mA max.) running through them. If the resistance exceeds a certain threshold it is considered "an event", and if ten events happen in a specific time-frame the channel is considered to be "failed".
I am a relative new-commer to NI DAQs and the associated software, so any advice would be greatly appreciated.
