Continuous DAQ with multiple Channels using 6023E
I am trying to countinuously aquire data from 8 channels using a 6023E (without loosing data). For some reason it allways gives me error -10092. Meaning the card requires a certain time between each scan.
If i set the scan rate to something that works, I loose
data. Does anyone know how to do this right without loosing data whilst using double buffering or is this
not possible?
(3,464 Views)
Greetings,
If the combination of the number of channels you are sampling and your chosen sample interval does not allow for a "gap" of time at the end of your scan interval, you will receive this error. I am assuming that you are using NI-DAQ function calls. If you are, which functions are you using? Which scan interval/sample interval combinations work, and which ones fail? You need to be certain that (sample interval * number of channels) < (scan interval).
Spencer S.
(3,464 Views)
I have a sampling rate of 30000 with three channels
(divisors 1,2,1) that should mean 30k,15k,30k the card can do 200k total. I want a seamless aquisition,ie no pause between scans.So theoretically a scan interval of 0. I got a seamless aquisition at lower frequencies but i dont understand the influence of scanrate on the sampling rate. With the samplerate at 20 and scan rate of 10 i get an aquiation rate of 7 Hz on my fasters Channels and about 3 Hz on the slowest.
I am using a double buffered aquisition using scan_setup and scan_start
(3,464 Views)
Ok I got somehow further.
My problem was understanding the relationship between sampling rate and scanning rate.
with E series the sampling rate is not the max sampling rate for a given channel but the overall sampling rate for A/D conversion. Further more
in order to avoid error -10092 you have to set the
scan rate to be slower than the sample rate:
One way is scanrate=samplerate/(NumberofChannelsUsed+1)
why this is necessary, i dont know?
so if you get 2 channels rate divisor 1,2 yields
SampleRate Channel1= scanrate/1
SampleRate Channel1= scanrate/2
ie. samplerate=100000 (10kHz)
3 channelsUsed -> ScanRate=25000 (25kHz)
divisors for each channel 1,2,1
means
channel1 samplerate=25 kHz
channel2 samplerate=12,5 kHz
channel3 samplerate=25 kHz
w
ith this i get a what looks like a seamless aquisition from Halfbuffer to Halfbuffer.
But I am not sure if all i mentioned is correct?
(3,464 Views)
Yes, it does appear that you have the correct understanding. The ScanRate dictates how often a new scan occurs. The SampleRate dictates the rate at which the channels within each scan are sampled or acquired. One question I do have regards your channel divisors. How are these being used? In which function do you specify these?
Spencer S.
(3,464 Views)
That would mean since i take 5 samples per scan
i would get with my sample rate of 100000 (sorry up there it should have been 100kHz) the following times:
time 0 10ns 20ns 30ns 40ns
Channel 1 2 3 1 3
then the next scan would start since i have a scan rate of 25000 (25kHz) the delay is 40 ns
meaning the next aquisitions have the following times
time 80ns 90ns 100ns 110ns 120ns
Channel 1 2 3 1 3
that is not seamless i loose time between scans
does anyone know how to make it seamless?
setting the rate devisors is done by defining the rate
divisor vector in SCAN_Sequence_Setup
if you have a rate divisor of 1 all over then the scan rate = sample rate of all channels i think
(3,464 Views)
