Spectrum Analyzer with NI-6111
I am trying to build a two channel (simultaneous) spectrum analyzer using Labview 7.0 and the PCI-6111 DAQ. I can make one channel work but it is very slow, but cannot find a method to acquire the second channel while the first is running. Are there any samples that might be useful? Attached is what I have so far. Is there anything I can do to speed it up? Any suggestions are GREATLY appreciated.
(2,741 Views)
I've attached an example that I've thrown together that acquires from two channels and performs an FFT of one or both channels (selectable). I didn't have a problem performing frequency analysis on multiple channels simultaneously. One thing to keep in mind though -- the more analysis you do while performing buffered acquisition, the more likely your CPU will run into trouble with transferring data. I hope my example helps.
Todd D.
(2,741 Views)
Thanks Todd,
Your comments on the buffered input was correct, taking the buffer out allows the program to run at near-real-time. The last addition to my program needs to provide an analog output. Do you have any suggestions on how I can add the output to the example I provided earlier?
Thanks again for your help!
Ted L
(2,741 Views)
