Multifunction DAQ
Continuous Digital Waveform Output on PCI 6602
I am using PCI 6602 to get continuous 1MHz square wave output from DIO1~32 sequentially controlled by LabVIEW. I used Ctr0 to generate a 2MHz clock and used Ctr0InternalOutput as the source of sample clock for DIO1~32. I attached the code and screeshots as follows.
The code is working fine on PCIe-6251 and the 1MHz digital waveform is very stable.
But when I run it on PCI 6602 I got an error -200077 (you have requested: sample clock; you can request: on demand).
Does PCI 6602 support hardware timing?. I didn't find information about this from its specs. If it doesn't support, how can I avoid this and get what I want? Thanks!
Yi
Version: LabVIEW 8.2
hardware: PCI 6602
(3,628 Views)
Accepted by happyeveryday
The PCI 6602 does not support hardware-timed digital waveform generation.  You can find this information on the product page or in the specifications document:
You can use the 8 counters of the 6602 to get 8 synchronized pulse trains, but clocking out arbitrary digital data is unfortunately not possible on this board.
Best Regards,
John Passiak
(3,618 Views)
John, Thank you very much! Yi
(3,596 Views)
