Continuous waveform generation with frequency change
Hi!
   I have a "problem" with a continuous generation or better, i solved the problem But i think it could be nice to solve it in a better way.
I have to generate an arbitrary waveformand change its frequency during generation. When i change frequency I nedd the new waveform to be continuous with the old one, so no stop and start between waveforms.
Before this, I used ALLOW REGENERATION property to conitnuously generate waveform that was a nice feature 'cause i don't need to write every time the new waveform.
Now to solve my problem I write every cycle iteration the waveform. To avoid being too slow, i write a buffer period > 500ms. This QUITE solve my problem, 'cause if some application automatically start and use PC resources i get an error from my application 'cause the buffer get empty.
So i create a shortcut of my applciation to launch it in High priority mode (cmd /c start /high myapplication.exe)  hoping this solve my problems.
My question is....is there the possibility to solve a problem like this using allow regeneration property and write the NEW buffer on the run? So i don't need to write as far as it possible but only write once when I need it.
Unfortunatelly at the moment it is not possible to change the allow regeneration property while the task is running.
(4,143 Views)
you can have a look at this example.
Try also to consider the properties described here.
I hope thos helps!
Bye,
Licia
(4,117 Views)
