02-03-2014 05:46 AM - edited 02-03-2014 06:02 AM
Hi!
I just changed a data aquisition task of 2 signals from "RSE" to "differential". After this the signals started to drift really bad. Could this happen because I haven't yet hooked up the DAQ to the actual voltage source? Also this loop is simultanously sending output signals to the DAQ outputs. I am just pretesting the configuration.
Thank you in advance.
Solved! Go to Solution.
02-03-2014 11:07 AM
Yes.
If you want you can connect the +5v from the board to the channels if you want an actual signal. But without anything hooked up the voltage can wander around.
02-04-2014 04:31 AM
Worked like a charm. Thank you! ![]()
