Controlling a solenoid and recording pressure
Jrsnitko,
Are you able to turn off the relay by setting the output low?  If you just stop the test panel the DO may very well maintain its current (high) state.
Sam K
Message 11 of 15
(937 Views)
What device is connected to the 9472? The relay or the solenoid?
What is the make and model of each device?
-AK2DM
Message 12 of 15
(932 Views)
If i switch it low the solenoid does shut-off.
Out of port 5 on the NI 9472 the relay is connected (8299K11)
Message 13 of 15
(928 Views)
Sounds like it is working then. You may want to put a reverse biased diode or supressor across the relay coil to prevent damage to 9472 output. The diode shunts the high voltage pulse that is generated when turning the inductive load (relay coil) off.
-AK2DM
Message 14 of 15
(925 Views)
I got my VI to work now the last thing I'm having trouble with is writing the 4 Pressure signals and the Elapsed time to a spreadsheet file.
Message 15 of 15
(894 Views)
