Create a virtual channel
I have examples for VB and NI, I have de NI Max, but when I connect my device, I can't do anything with my program. What can I connect my VB program with my device? I read that I have to create a virtual channel, but I don't know how...
Thanks.
(4,286 Views)
Hi J_Kidd,
here you are several documents that you can use as a starting point better than coding from scratch. They will help you to narrow down your issue:
https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGZtCAO&l=en-US
You can visit the following links for further information:
https://www.ni.com/en/shop/data-acquisition.html
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
I hope this helps!
Jesús
(4,234 Views)
