Error 200290
I have written a VI to ramp a voltage signal to a solenoid, whilst simultaneously reading a voltage signal from a load cell and monitor a switch. It is part of a load calibration VI I have created for some lab equipment.
The VI keeps crashing with the error 200290. There seems to be little pattern to when this occurs.
I've attached the VI.
I'm concerned I’ve fiddled with the VI too much and have made it more complicated than is necessary.
(4,939 Views)
Hi C.Myant,
Thank you for your question.
Please have a look at this KnowledgeBase Article:
Error -200290 When Performing an Event Driven, Buffered Analog Output Operation with NI-DAQmx.
Community Admin Note:  The article link has been removed due to invalid information.
It explains the reason and a potential solution to Error - 200290.
I hope it helps!
Kind Regards,
(4,911 Views)
