Multifunction DAQ
Creating a 64kHz current signal with a DAQ?
I am going to do some impedance measurements and need a device to generate a 64kHz low current(0,1mA) signal, and to pick up 2 differential voltages. Is there any multifunction DAQ devices that outputs a constant current or can i use a device with a voltage output and use a voltage to current converter?
Adam
(3,276 Views)
Accepted by Adamgot
I'm not aware of a metrologic current source for 100µA @ 64kHz ..
I would try this:
http://www.edn.com/design/analog/4324499/Bipolar-current-source-maintains-high-output-impedance-at-h...
Why not just apply a AC voltage and measure current and voltage(s) ?
Another way to apply a 100µA rectangular waveform: Place a REF200 (2 100µA references) in a diode bridge and apply a 64kHz squarewave 🙂
Greetings from Germany
Henrik
LV since v3.1
(3,244 Views)
And can you tell me which suggestion you choosed?
Henrik
LV since v3.1
(3,217 Views)
