D/A output
We're using a National Instruments BNC-2090 board,
serial number A40CE9, and want to know the range of
possible voltages for a D/A signal.
(2,703 Views)
Greetings,
The BNC-2090 is a connector block for the interfacing of a DAQ device to signals, other devices, etc. Most likely, you are using your BNC-2090 with an E-Series DAQ board. In this case, you have two available output ranges: +/-10V (bipolar) and 0-10V (unipolar). If you desire a different output range, you must supply an external reference. Below is a link to a document that discusses this option:
Outputting a Voltage Using an External Voltage Reference
Good luck with your application.
Spencer S.
(2,703 Views)
