How many DMA Channels has AT-MIO-16E-10 ?
Hi there! I have AT-MIO-16E-10 board.In the users manual regarding to DMA it sais the following :
" The AT E Series boards can achieve high transfer rates by using up to three 16-bit DMA channels. You can use these DMA channels for data transfers with the analog input, analog output, and general-purpose counter sections of the board. The AT E Series boards can use only 16-bit DMA channels, which correspond to channels 5, 6, and 7 in an ISA computer and channels 0, 1, 2, 3, 5, 6, and 7 in an EISA computer. These selections are all software configured and do not require you to manually change any settings on the board."
1.If E-Series can use up to 3 DMA channels for high transfer rates how many DMA channels are availab
le for AT-MIO-16E-10 ?
2.How many IRQ's are available for AT-MIO-16E-10 ?
3.Regarding to an application for AT-MIO-16E-10 , the Count Edges (DAQ-STC).vi which is attached bellow,how the counting operation it's performed ? Through DMA or through interrupts ?
I'm waiting for your answers as soon as possible.
Michael.
(2,911 Views)
1.If E-Series can use up to 3 DMA channels for high transfer rates how many DMA channels are available for AT-MIO-16E-10 ?
The AT-MIO-16E-10 has three 16-bit DMA channels. Check page 2-4 of the manual.
There is one IRQ channel available. Check the same page of the manual, 2-4.
The card by default uses the available DMA channels; if all the DMA channels are used by different operations (e.g., AI, Counter...), the card switches to IRQ. Y
ou can software select if a configured operation shall use DMA or IRQ to transfer data to the PC memory -- in LabVIEW, for instance, you can use the Set DAQ Device Information.vi.
Ramzi.
(2,911 Views)
Ramzi thank you for your answer. I must ask you some more questions about this.
1. Can you give an example about a counting application that uses IRQ's instead DMA's ? Or a PWM generation block that uses IRQ's explicitely instead of DMA's ? I'm looking for a vi application.
2.If AT-MIO-16E-10 has 3 DMA channels and 1 IRQ channel and i want to perform 2 operations with 2 counters through IRQ's (i explicit write that in the code of the application) can I ?
Thank you very much for reading this and i'll be waiting for your answers as soon as possbile,
Michael.
(2,911 Views)
Michael.
(2,911 Views)
Thank you very much for reading this and i'll be waiting for your answers as soon as possible,
Michael.
(2,911 Views)
