Multifunction DAQ
DAQ 6008
when i go to configure an Analogue Input for example on the DAQ it comes up "No products Supported"
I had this working yesterday but now nothing,
I re-installed all the software to see was it the software but the same thing comes up.
I tried to re-install the DAQ Software but this comes up as " Fatal Error, Unable to create temporary file " and wont let me install this.
what should i do
thanks
B
(3,495 Views)
The error messages you are experiencing are similar to those described in this KnowledgeBase article. Are the ones you've written in your post Verbatim?
http://digital.ni.com/public.nsf/websearch/179BC9B0266168288625722100738C22?OpenDocument
If this article doesn't help you then post back here.
Good Luck
Tom.
NIUK
(3,468 Views)
I am getting the same problem when I try to do an analog input with the no products supported.
I have read the article
and i have confirmed that
1. I have installed daqmx base 2.1.0f0 and daqmx driver version 8.3.0f3, running labview 8.0
2. The device appears in MAX under usb devices and also in device manager under NI-VISA USB Devices as NI USB-6008 Multifunction IO
I have ran the DAQ diagnostic utility 2.0 and it does not detect the device there either.  I am also using powered usb ports.
Any Ideas?
(3,406 Views)
Take a look at this - http://digital.ni.com/public.nsf/websearch/1448A8AC665EE0EA8625703F004A4410?OpenDocument This may help you, it discusses the issues faced when using both DAQmx and DAQmxBase within LabVIEW with USB Devices.
Hope this helps!
Tom.
NIUK
(3,389 Views)
