DAQ 6353 on linux
I'm new to National Instruments products. We have a NI PCIe-6353 X Series Data Acquisition board, and would be of our interest to use it under linux.
Is it possible, or they are incompatible?
Best regards.
(5,511 Views)
Hi!!!
You are using a X Series board, which uses the DAQmx driver.
On the links below you'll find helpful information:
NI-DAQmx and NI-DAQ Driver Support: Main Page
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Programming Data Acquisition for Linux with NI-DAQmx Base
https://www.ni.com/en/support/documentation/supplemental/21/programming-data-acquisition-for-linux-w...
Barbara Pracek
Engenharia de Aplicações
National Instruments Brasil
(5,492 Views)
Thank you very much Barbara, I wonder how I missed those pages.
Best regards.
(5,487 Views)
Hello again, I've another question, about this board.
Is it possible to install one board PCIe 6353, and another equal (or very similar) on the same computer?
I need 8 analog outputs (the 6353 has only 4), so with another board, of 4 analog output, I can solve my problem, if they work together without problem in the same motherboard...is it possible to do?
Best regards!
(5,400 Views)
Hey!
That's no problem you can use two equal boards on the same PC. Smiley Wink
They are indentified by the serial number, therefore there is no possibility to any type of conflict.
Barbara Pracek
(5,390 Views)
http://www.ni.com/white-paper/6910/en/
According to that page, the 6353 is not supported on Linux, unfortunately.
(5,116 Views)
