DAQ 9.7 DAQmx Task clear - long delay by call of nilvaiu.dll
I set up a new PC which needs to run an older version of LabView2009 SP1 on a Windows 7 32bit system.
The system includes 4x PCI-6110 and one PCI-6259. I am using DAQ Version 9.7.
All cards are present in NI MAX and succeed the self test. Test panel works for all cards and all channels without problem.
But DAQ-assistent in Labview does not work properly. If I add the DAQ-assistant to the diagram, select voltage measurement task for channel AI0  of PCI-6259 and start the measurement with default setting, the DAQ-assistent freezes for aprox. 20s after the measurement diagram is updated.
For further debugging I opened the frontpanel of the DAQ-assistent and found that "DAQMX Clear task.vi" calls "nilvaiu.dll", which causes the freeze of 20s.
Do you guys have some thoughts for me to try next? Unfortunately I cannot use a higher LabView version atm.
Message 1 of 1
(1,846 Views)
