Power cDaq 9132 v1 and v2
Hi im working with a cDaq that is not mine i don't have the original connector for the power supply.
I have one but I don't know if i have to connect both V1 and V2.
I read the specifications but I only found the maximum ratings.
Should I power both?
I tried with V1 alone but apparently it didn't turn on.
Thank you in advance.
Regards.
My Channel: https://www.youtube.com/@LV_Lab
(1,925 Views)
It turned on with v1.
I didn't connect it properly the first time.
Is it appropiate to delete this post?
(1,904 Views)
