DAQ AO Ouput voltage decreases with higher frequency
I am attempting to generate a 20KHz +/-10V signal with the PXIe-6363, however the amplitude on the 20KHz signal is only 1V pk-pk. How can I get better control of the output amplitude? I am using an AO port.
At 10KHz the signal is 2V pk-pk and at 1K 15.8V
At 100 Hz - 20V pk-pk ish.
Samples per buffer = 100
Cycles per buffer = 10
Waveform = Sine Wave
Using the Cont Gen Voltage Wfm-Int Clk example.
(3,164 Views)
What is your sample clock rate? How are you measuring the output?  What is the load?
Lynn
(3,162 Views)
Hi dmbtj,
In addition to johnsold's questions, it would also be useful if you could tell us about any capacitive/inductive characteristics present in your setup.  You may have a inadvertently created a low-pass filter in your system that is attenuating higher frequencies.
Chris Elliott
x36772
(3,133 Views)
