11-14-2012 08:08 PM
the output data that comes from a single wire from the instrument without the ground signal from the instrument , ie , the open collector output data. which is the cheapest and the best NI hardware to acquire open collector output data ?
Solved! Go to Solution.
11-15-2012 06:43 AM
cross posted on LAVA:http://lavag.org/topic/16327-acquisition-of-open-collector-output-data/
As said in the LAVA thread, there has to be a ground reference somewhere. Now the question is are you trying to measure the output voltage or the state of the output?
