DAQ Assist Fails
i have problems with my DAQ-card 6024E and LabView 7. In MAX is may daq-card installed, and all tests are working properly.
then i start 'new vi' and put DAQ-assist on block window. i start then my DAQ- wizard and what i want is to configure ANALOG INPUT or something else. anyway, for "my physicaly channels" wizard says: 'no supported devices found'. ?!? how that can be? i have card that properly works in MAX but not in DAQ-assist
have LabView 7 and DAQ 7.01
thanx
Vedran Divkovic
Ruhr Uni Bochum
Departement: PY
Germany
(2,639 Views)
The DAQ-card 6024E isn't supported in the DAQmx API in DAQ 7.01. You need to upgrade to DAQ 7.1 if you want to use the DAQ Assistant with this device.
(2,639 Views)
