Why does AI_VRead always return -10403?
I am using a PCI-6014 board for single point analog I/O using the AI_VWrite and AI_VRead functions. I have written an application in C that does exactly what I want, as long as I run it on the computer in which the 6014 resides. But I need to run it remotely using the RDA server utility. When I do this, the AI_VWrite functions still work, but the AI_VRead functions always return -10403. But I know that it is possible to make this work because I can run the Measurement & Automation explorer on the same system and it successfully reads my anlog inputs from the remote system. What is my problem?
(2,925 Views)
Pentec,
The document linked below includes the following comments:
"RDA works with LabVIEW, LabWindows/CVI Easy I/O, and VI Logger under Windows XP, Windows 2000, Windows NT, and Windows 9.x. Currently this feature is not available for third-party compilers, such as Visual C or Visual Basic, or for Mac OS."
Are you developing in CVI? The AI_VRead() function is not part of the Easy I/O library, so it is not compatible with RDA. If you are using CVI, you should use the Easy I/O functions. If not, you will need to consider one of the supported development environments.
Networking Two PCs for Remote Data Acquisition
Good luck with your applic
ation.
Spencer S.
(2,924 Views)
I have been using RDA with my own app written in C and it works fine for some things but not all functions are supported.
(2,924 Views)
