Multifunction DAQ
DAQ CARD cant generate trajectory
Though you've got a good-enough solution now, I'd like to point you to another thread where I eventually posted an example.  I've long wished for a buffered counter output mode that would allow us to define an exact # of precise but varying periods.  I STILL think it's a glaring hole in the data acq driver and continue to wish and hope.
Anyway, a different method that may just a bit better than what you've got is to create a timed loop which uses the counter pulsetrain output as a timing source.  My example at the end of the thread demonstrates only a ramp-up acceleration so some work would be needed to handle ramp-down or both or whatever else.  Think of it as illustrating an approach, and maybe it'll give you a little boost.
HOWEVER, there's an even better method available for your M-series 6221 board provided you know the entire desired trajectory ahead of time.  You can use the "correlated DIO" capability of your card to predefine a digital output buffer that represents the entire variable-rate pulse train trajectory, and then generate the pulses with 1 microsec precision.  You'd need one of your counters to act as a 1 MHz sampling clock for the DO task.
-Kevin P.
Message 11 of 12
(896 Views)
Kevin!
Thank you for your suggestions. I will see what I can do with the "correlated DIO" method.
Thom
Message 12 of 12
(876 Views)
