DAQ Device
Does NI have a DAQ device that is comparable to the PCI 6025e? Required functions are 12 DIOs, 2 AO, 5 AI, compatible with C#, and a 68 pin or USB interface.
(2,741 Views)
Thanks for posting on the NI forums!  You didn’t mention a sampling rate requirement, but if you are looking for a low cost M series card that is comparable to the PCI 6025E, then the PCI 6221 is a great choice.
Check out the M series product page if you require higher performance.  On the left, you there are options for High Accuracy, High Speed, Low Cost, Industrial and USB bus-powered M-series devices.
Also, our DAQmx driver which ships with the device is compatible with C# as well as other .NET languages.
Message Edited by RT4CY on 06-18-2008 03:27 PM
Rod T.
(2,714 Views)
