Has anyone used the nidaq with python on a 6008 in a multi channel enviroment? I get spurious results in Diff mode
Hi
Language Python 2.5 with the nidaq library
Mode: DAQmx_Val_Diff
Device: USB 6008 Analog input
The short question:
How do I get multiple channel data from the 6008 at the same time? The freq should be 6 reads per sec on 3 channels
If I call the get_data function below, the tuple returned is fine for 1 channel. If I thread it, then I get odd results
The data below was a 1.6v dc (battery) connected to 1 of the 3 channels continuously.  So why the 0.0369321676022 result?
With 1 channel, I get a constant correct reading
0.0301219406728#0.0301219406728#0.0369321676022#0.0301219406728#0.0301219406728#0.0301219406728#
0.0301219406728#0.0369321676022#0.0301219406728#0.0301219406728#0.0301219406728#0.0301219406728#
0.0216441357288#0.0301219406728#0.0301219406728#0.0301219406728#0.0301219406728#1.61159945056#
0.0301219406728#0.0301219406728#0.0301219406728#0.0301219406728#0.0301219406728#1.61159945056#
0.0301219406728#0.0301219406728#0.0301219406728#0.0301219406728#1.61159945056#0.0301219406728#
0.0301219406728#0.0301219406728#0.0301219406728#0.495573123804#0.0301219406728#1.61669546119#
0.0301219406728#0.0301219406728#0.0420281782266#0.0301219406728#0.0301219406728#0.0301219406728#
1.61159945056#0.0301219406728#0.0301219406728#0.0301219406728#0.0301219406728#1.61159945056#
0.0301219406728#1.61159945056#0.0301219406728#1.61159945056#0.0301219406728#1.61159945056#
Thread Example
        self.lock=thread.allocate_lock()
        thread.start_new_thread(self.myThread1,("myThread1",self.lock))
        thread.start_new_thread(self.myThread2,("myThread2",self.lock))
        thread.start_new_thread(self.myThread3,("myThread3",self.lock))
def get_data(chan):
        # initialize variables
        taskHandle = TaskHandle(0)
        max_num_samples = 1000
        data = numpy.zeros((max_num_samples,),dtype=numpy.float64)
        # now, on with the program
        CHK(nidaq.DAQmxCreateTask("",ctypes.byref(taskHandle)))
        CHK(nidaq.DAQmxCreateAIVoltageChan(taskHandle,"Dev1/%s" % (chan),"",
                                           DAQmx_Val_Diff,                  #DAQmx_Val_RSE,       #DAQmx_Val_Cfg_Default,
                                           float64(-10.0),float64(10.0),
                                           DAQmx_Val_Volts,None))
        CHK(nidaq.DAQmxCfgSampClkTiming(taskHandle,"",float64(10000.0),
                                        DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,
                                        uInt64(max_num_samples)));
        CHK(nidaq.DAQmxStartTask(taskHandle))
        read = int32()
        CHK(nidaq.DAQmxReadAnalogF64(taskHandle,max_num_samples,float64(1.0),
                                     DAQmx_Val_GroupByChannel,data.ctypes.data,
                                     max_num_samples,ctypes.byref(read),None))
        #print "Acquired %d points"%(read.value)
        if taskHandle.value != 0:
            nidaq.DAQmxStopTask(taskHandle)
            nidaq.DAQmxClearTask(taskHandle)
        return data
Message 1 of 1
(2,950 Views)
