DAQ_STC_DIO_Control_Register on the PCI-6035E
The "PCI E Series RLP Manual" from Nov 1998 does not contain the address of the DAQ_STC_DIO_Control_Register on the PCI-6035E ! I need access to this register (in direct or windowed mode), in order to control the EXTSTROBE output by software. Can anyone help?
(2,447 Views)
The DIO Control Register is at offset 0x0B (decimal 11) in the STC and needs to be accessed using windowed mode. The DAQ STC Technical Reference Manual contains all relevant information.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(2,447 Views)
