DAQCard 6062e reports "Interrupt-Level 0 ist not available" - error 10452
I am using Windows XP SP1 on an AthlonXP 1800+,NI-DAQ 9.8.3,LabView 6.1,MAX 2.2 and a PCMCIA Card Reader RICOH R/RL/5C476. What should I do to get this card working properly?
(2,713 Views)
Correction:
"device does not respond to first IRQ-level"
reports "resource testing option" in properties of DAQ Card 6062E in MAX 2.2 (using NI DAQ 6.9.3)
starting test panel and changing data type to "continuous" or "curve progression" in analog input causes error 10452
(2,713 Views)
Hello;
The first thing you need to double check is if the socket driver that is in use is the Native Microsoft sockets driver.
In case it's not, we can't guarantee the NI-DAQ driver to communicate properly with that driver. You can uninstall the third party driver and install the Native Microsoft driver from the Windows Installation CD.
Hope this helps.
Filipe A.
(2,713 Views)
I am having exactly this problem with both a DAQcard 1200 and DAQcard 500 on an "out of the box" HP Pavillion 4100 with a celeron running XP SP1. It appears that the serial number is not reading so it appears to be related to another app question about erroneous readings and PCMCIA socket numbers...
O2Micro OZ6912 cardbus controller, Microsoft 5.1.2600.0 driver, NIPALK,sys 1.5.6f0 driver
(2,713 Views)
