DAQ assistant triggers only at second signal
Dear all,
I'm a newbie in Labview and I am struggling with the DAQ assistant.
I generate a signal using NI9263 at AO0.
The generated signal at AO0 is a pulse-like train between -10 and 10V. Meaning it is always 0V, but then goes to +10V for a short time, then to 0V for a short time, then to -10V for a short time and back to 0 V. I can generate this pulse-train using a front panel button. Every time I press the button, a single pulse-train is generated. That works fine.
I want to read this signal back using NI9205 at AI0. Therefor I use the DAQ assistant in analog trigger mode on AI0, level 5V.
I set the triggering to wait infinitely. I placed this code in an infinite while loop.
When I run the code, I first press the front panel button to generate the signal and I see this is happening on an oscilloscope.
But, the triggering does NOT occur. When I press a second time the front panel button to generate the signal, THEN a trigger occurs.
Triggering seems to work only after I twice generate the pulse-train. So triggering happens on the 2nd press, on the 4th press, 6th, ...
Why does it not trigger on all the events?
Thanks!
(3,386 Views)
Hard to tell without seeing the code, but my guess is you've got a problem in the dataflow.  Make sure things are happening in the order you expect them to.
(3,370 Views)
Hi Claude,
Were you finally able to find a solution?
If still needed, and as SnowMule suggested already, if you share your code someone will probably be able to help you...
Kind regards,
Cédric | NI Belgium
(3,293 Views)
