Multifunction DAQ
DAQ customized signal acquire
My project requires to acquire digital signals with a definite pattern, repeating itself for every defined time interval.
I am using NI-6259, 6722 pxi DAQ cards.
The signal looks somethin like this Attached bmp file.
Can anyone help me out how to proceed with this?
Smitha
(3,204 Views)
Hi
What you want to do with excatly......
do you want to accquire the wavform?
give some more detail
Regards
Ell Dee
(3,196 Views)
Accepted by Smitha.Alse
Hey smitha,
It sounds like you are wanting to acquire some digital signals. One easy way to get started with data acquisition in LabVIEW is to use the DAQ Assistant. I have linked a couple of articles below that should get you started. You can also find more advanced DAQmx examples in the LabVIEW Example Finder at Help » Find Examples » Hardware Input and Output » DAQmx » Digital Measurements.
NI-DAQmx Express VI Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/2744
Complete Data Acquisition Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/3116
Chris Delvizis
(3,175 Views)
