DAQ device
I am using PCI 6250 and NI 5112 DAQ boards. I would like to add reset button, enable button, beep button and shock button for my application. Do you have any information or examples that I can take a look for my application? Attached is my application.
(3,044 Views)
duplicate post. You got a great example in your other post of the same question. If you had questions regarding it, you should have responded back in the original post and not started a new thread. You need to check into LabVIEW training for basics on creating front panel controls. There are links to classes, books, and on-line turorials at the LabVIEW Training Center.
(3,029 Views)
