Multifunction DAQ
DAQ digital output default to low/ground
This probably a basic question, but I couldn't find information about it.
When I connect a DAQ unit (usb6009) to the USB port I get all the digital output to default to a high state (+5V) until I run my program and I set them to low/ground.
Is there a way to configure the DAQ to always default to 0V?
I'll appreciate any comment or links about how to change that.
Thank you,
Cristian
(3,779 Views)
Accepted by Ibanez
The default for the 6009 is they are all set for inputs. What you are seeing is the pull up. But, no, you cannot set the power up state of the 6009.
(3,772 Views)
Thank you
(3,768 Views)
Thank you
(3,766 Views)
