DAQ digital output default to low/ground
This probably a basic question, but I couldn't find information about it.
When I connect a DAQ unit (usb6009) to the USB port I get all the digital output to default to a high state (+5V) until I run my program and I set them to low/ground.
Is there a way to configure the DAQ to always default to 0V?
I'll appreciate any comment or links about how to change that.
Thank you,
Cristian
(3,770 Views)
Accepted by topic author Ibanez
The default for the 6009 is they are all set for inputs. What you are seeing is the pull up. But, no, you cannot set the power up state of the 6009.
(3,763 Views)
Thank you
(3,759 Views)
Thank you
(3,757 Views)
