DAQ setup error
Blue Screen trying to install DAQ 6.9.3 in Win98 SE.
VXD Error (VMM)
(3,171 Views)
Did you try more than once to see if it happens repeatedly? If yes, please let me know what is the message on the screen that you get.
Did you try to insall the NIDAQ version that is available from web?
Also please do let me know in details what steps have you followed while installing so that I can track what is the problem.
Also please take a look at the following support link on the related problems to see if it helps you in resolving the issue.
Keywords Search: ni-daq blue screen
Sincerely,
Sastry Vadlamani
applications Engineer
Message Edited by Molly K on 02-19-2005 12:04 AM
(3,172 Views)
Thank you very much for the prompt answer.
I solved the problem by installing the newer Windows XP operating system.
Anyway I tried many times to install the 6.9.3 version of DAQ downloaded from the web site of NI.
After 5/6 attempt to install the software without succes
I decided to install a fresh version of XP operating system and all went well.
Now I have the DAQ up and running on my system.
Thank you again.
Gabriele Salvato
I.P.C.F del CNR
Via La Farina, 237
I 98123
Messina
Italy
(3,171 Views)
Thank you very much for letting me know. Good Luck with you application.
Sincerely,
Sastry V
(3,171 Views)
