DIO lines and counters on NI 6036E
Hi my name is Gestur. I'am trying to generate a finite pulse train with the counters on my E serie 6036E DAQ board - which works fine - but at the same time, reading and writing to and from DIO lines. This has been giving me problems. I've building a test program which works with cases, where like case0 writes a low level to a DIO line. In case1 i start the counters, generating my finite pulse train. Then i notice that the same DIO line that earlier was lowered, is high again.
Another problem is making a analog input sampling, which is supposed to enables on every rising edge of my pulse train. I have on the I/O connector linked the output from the counter, to the EXTCONV pin. This works fine, but not! Because the analo
g input sample seems to block actions in my pulse train vi where i'm tryin to read from DIO. This is a bit difficult to explain, but i will attach a vi which might explain this.
I hope this is something to understand and i hope that you are able to help me.
Thank you for your time
Kind regards Gestur
(2,429 Views)
HI,
The attached VI's have some missing sub-VI's. Can you use the VI Library manager and gather all the components together into one .llb?
mike
(2,429 Views)
