DAQ which can measure high resistance value...
I am working on a project wherein I am using tactile (pressure) sensor. I need to measure pressure in real time(continuously).
I am currently using NI-DAQ 6221. Using DAQ assistant VI, I wanted to see pressure values at different instances. But unfortunately, when I click on acquiring force or pressure it shows "NO SUPPORTED DEVICES FOUND". Hence I decided to measure resistance values to set required threshold levels. But I faced another problem here.
The maximum resistance which 6221 can measure is limited to 10K. But the amount of pressure applied on the sensor will give resistance values more than 10K. So please help me with DAQ models which can:-
1) Either measure pressure or force directly  and/or,
2) A DAQ model which has higher resistance measuring capability....(upper range should at least be 100K)
Gaurav
Message 1 of 1
(3,079 Views)
