how do you read multiple signals (temp,pressuren,freq) on x-series
hey,
i'am new at labview and i have a problem. I'm have 5 separate programs for measureing temp,pressure,speed,...
every program on its self works good but if i want to put them together it fail,i have no idea how to read or send multipe signals at the same time.
so is their somebody here who can help me???
greets joachim
(3,501 Views)
You just need multiple DAQmx Create Channel functions all using the same task. If you are using the DAQ Assistant, create a task for one channel/type and then open it and click the Add button.
(3,498 Views)
don't you have an easy example were for example 2 signals are being read??
that would help verry much
greets joachim
(3,492 Views)
Just this simple:
(3,478 Views)
thanks alot
its working fine now
(3,462 Views)
