06-13-2005 01:35 PM
06-14-2005
11:54 AM
- last edited on
07-13-2025
04:00 PM
by
Content Cleaner
Hi hayazh,
Were you sure to install the driver before putting the hardware in your computer? Also, if you installed the driver from a CD, you may want to try removing the device, uninstalling the driver, downloading it from our website and installing that.
If you look in the device manager at your DAQCard 1200, do you see an exclamation point or question mark over it? If you do, I would suggest deleting it from the device manager and then scanning for hardware changes. After doing this, you can go into Measurement and Automation Explorer and press F5 to refresh. You mentioned that you have multiple DAQCard 1200s, have you checked for this same behavior with another device in this computer?
Laura
06-14-2005 03:14 PM
10-06-2006 02:46 PM
11-28-2007 12:21 AM
