DAQCard-1200 driver for Labview 7 express
Hi there,
I'm working on a station using LabVIEW 5.1 and DAQCard-1200. This station doesn't be connected to the internet and stand alone.  I tried to use a LabVIEW 7 software to replace the LabVIEW 5.1 software but got the following error messages:
"The ordinal 2011 could not be located in the dynamic link library nidaq32.dll"
"DIO port config.vi error. code 21: an external subroutine required for execution could not be found."
How can I solve this issue?
Thanks for your help!
(3,896 Views)
Hello cannigia,
Unfortunately, as you can see here, the latest DAQ driver that the supports the DAQCard-1200 is Traditional NI-DAQ Legacy version 6.9.3. If you view the download page for this driver, you will see that it only supports LabVIEW 5.0, LabVIEW 5.1, LabVIEW 6.0 and LabVIEW 6.1. Therefore, you cannot use the DAQCard-1200 with LabVIEW 7.0.
Matt Anderson
Hardware Services Marketing Manager
(3,878 Views)
