DAQExpress logging
Hi, I am switching from SignalExpress to DAQExpress. In SignalExpress there used to be an option to automatically export log to text file. I can't find this option in DAQExpress (Analog Input.task). I could really use this option when I have a large number of recordings, so I don't have to manually export each log to txt (or csv) file. Any ideas?
(2,901 Views)
Right-click on the recording in the project window.  There is an "Export" option.  Looks like the default file type is a CSV.
(2,809 Views)
Thank you for your answer. I am aware of that option. However, it requires me to manually export each log. I would like every log to be automatically exported to .csv (or .txt) after logging stops.
(2,796 Views)
Hi Ved,
I am kind of stuck at the same point. I want my function to automatically create .CSV files after each cycle. Any ideas would be highly appreciated.
(2,667 Views)
