9263 settling time
Hi pals,
I am outputting a square signal and reading that signal back using NI-9263 and NI-9201 respectively. Nevertheless I am getting dynamics on the output signal or at least that is what I am measuring via NI 9201.
In image 1, I am showing a segment of the signal where evidently there is a overshoot on each step up and down. Image 2 is a zoomed version of Image 1 to emphasis the overshoot present in my measurements.  Settling time is around 5 times than the specs (13u sec) and signal overshoots 50%
My sampling is done at 100k Hz that is the maximum speed of the NI9263.per channel.
I appreciate your time. Kind regards,
David
(2,367 Views)
I also met the overshoot problem. Have you solved this problem?
(1,965 Views)
I did not solve it, but it seems like the way to solve it is a calibration of the device. Fortunatelly, I did have another device and it works perfectly. If you have another device change it and test it.
Hope you solve it. Best wishes,
David
(1,955 Views)
