DAQmx 1510f3 NationalInstruments.Common an NationalInstruments.DAQmx missing
Hello Everybody we change the operation system from WinXP to Win8.1 (64bit) after reinstallation of DAQmx I can't finde the above mentioned :net assemblies. I develop my application in VS2010Express. Can everybody helps me and says to me where I can find the .dll?
Best regards
EbbeSand
Message 1 of 9
(5,002 Views)
Best regards
EbbeSand
There is no such thing as VS2010 Express.
I do have VB.NET 2010 Express and C# 2010 Express and C++ 2010 Express
Message 2 of 9
(4,992 Views)
I use VB.net 2010 Express
Message 3 of 9
(4,988 Views)
Did you install it before or after installing NI-DAQmx ?
You'll need to go back and modify your NI-DAQmx installation to support .NET 4.0 Framework.
Message 4 of 9
(4,981 Views)
I install first VB.net 2010 Express and then NIDAQmx the  support .NET 4.0 Framework. is only possible if I had a full licence of
Measurement Stuido. That is what the NI-DAQmx installer said.
I everybody kown a older Version of NI-DAQmx that run on Windows8.1 (64bit)
Ebbe Sand
Message 5 of 9
(4,978 Views)
Ebbe Sand
It is possible to use NI-DAQmx with VB.NET 2010 Express without having a license for Measurement Studio.
The DLL files will be installed if you select support for .NET 4.0 Framework whether you have Measurement Studio license or not.
Message 6 of 9
(4,969 Views)
With the above mentione Version 15.1.0 of NI-DQAmx it is not possible
Sorry for the German Text but I only had a Gewrman Version
Ebbe_Sand
Message 7 of 9
(4,951 Views)
Ebbe_Sand
Since you don't have Measurement Studio 2015, you won't get the VS2010 integration.
That will not prevent you from calling and using DAQmx functions in VB.NET 2010 Express.
Message 8 of 9
(4,940 Views)
Thanks, for your help now I installed a lower Version (14.5.1) there the Integration of the .net class common and DAQmx works fin
Ebbe_sand
Message 9 of 9
(4,926 Views)
