Deploying my project to cDAQ makes LabVIEW crash.
Has anyone witnessed LabVIEW crash when deploying code to their cDAQ 9139?
The crash report pop-up gives these details:
DAbort: 0x89B93EF0 in image.cpp
Version: 14.0.1 (32-bit)
DMCM
(4,471 Views)
Correction to my observation:
When nothing is deployed to my cDAQ, and I chooose run LabVIEW crashes.
If nothing is deployed to my cDAQ, and I choose deploy first then run I avoid crashing LabVIEW.
Note: I've recently made changes that have made one VI be massive compared to others.
(4,470 Views)
DMCM,
What kind of cDAQ 9139 are you using, are you using Windows or Real-Time system on the chasse?
Part Number: Windows-782325-01
Part Number: Real-Time -782326-01
Sarina
Applications Engineering
(4,439 Views)
Sarina,
I ordered a Real-Time system. Is there a way to verify this using the serial number? I don't know where my papers are located for this unit.
DMCM
(4,405 Views)
DMCM,
The easiest way to figure out which one you have based on the serial number is to create a service request and call into NI support (866-ASK-MYNI) or email NI support.
With the serial number we can verify which product has been purchased. I would advise not posting the serial number on the discussion forum.
Sarina
(4,386 Views)
Lol, yeah I figured as mush.
(4,384 Views)
