DAQmx Base for PDA custom application
Will NI-DAQmx Base for the PDA work when not using LabView?  I have a custom application using the DAQCard 6036e and I am having trouble with the driver.  I am being told to use DAQmx Base, but it appears to me this only works on the PDA if you use LabView, which I do not.
Can anyone tell me how to install (if possible) NI-DAQmx Base on a Windows CE platform that is NOT using LabView?
Justin Allen
Utz Tech LLC
(3,014 Views)
Hello Justin,
NI-DAQmx Base only offers support for Window CE through a LabVIEW API.  This is because the driver is built on and comprised of LabVIEW VIs.
Micaela N
(3,004 Views)
