Multifunction DAQ
DAQmx Digital Output task works with DAQmx Read
Can someone explain why this snippet works?
A digital output task is created and a DAQmx Read works with it, shouldn't the output task only work with DAQmx Write?
Thanks in advance
CLD
(2,589 Views)
Accepted by ArAmM
Hi ArAmM,
It is intentional.  Here's a KB with a similar code snippet explaining that this is supported.  It works because the read is returning the current value being output--it does not change the line direction.  You are still driving the line(s) in your task.
(2,556 Views)
