DAQmx Tasknames?
at the moment i am programing software for testequipment that has to run on different computers. So I would like to get the DAQmx Tasknames through a function call. Unfortunately I only found the GetTaskName function which needs a Taskhandle. But I want to know all the available tasks, that the user can choose the one he needs.
Has anybody an idea?
(3,096 Views)
SteJap
Try using the DAQmxGetSysTasks property. It should return an array that contains the names of all tasks saved on the system. Hope this helps
StuartG
(3,086 Views)
Thank you for your answer. Now I know why i have not found this function. It is not documented in the C Reference Help.
Do anybody know where I can find the documentation about this function?
(3,075 Views)
It's documented in the NI-DAQmx C Reference in the section NI-DAQ C Properties; not under C functions.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,069 Views)
