How to read LV 7.1 eaxmple codes with 6.1 ?
I'd like to look at one the example vi posted in NI's web.
But it is coded by version7.1.
How can I read those in LV version 6.1, which I have.
Thank you.
-chung
(3,455 Views)
Unfortunately this is not possible. The solution is to ask someone who uses LV7.1 to convert the example back to 6.1. No problem as long as the example don't uses vis that are not supported by LV6.1.
I'm willing to do this for you. Where can I find the example and what is your email adress ?
(3,450 Views)
Chung,
If you post your VI to this discussion forum or just post the link where you found the example I will convert it to LV 6.1 for you. JB is right, you cannot take an example from LV 7.1 and open it in an earlier version. You can go from an earlier version to a later version though.
JenK
(3,449 Views)
Here is the code I downloaded from Ni.com.
Thank you.
(3,430 Views)
Chung,
I have saved the files for LabVIEW 6.1. This should work.
JenK
(3,409 Views)
To JenK.
Thank you. But there is an error in the code....
(3,398 Views)
Here, this one has no errors.
-Alan A.
(3,387 Views)
