Multifunction DAQ
DAQmx Trigger: Error 2200077
I'm trying to create a program to trigger on a hammer signal, using an USB-6211 card and 4 Analogic Inputs (using 1 DAQmx Create Channel AI Voltage for the hammer and 3 other to the accelerometer output). Having as base some LabView examples like "Cont Acq&Graph Voltage" and "Impact Test(DAQmx) [SVXMPL_Impact Test(DAQmx).vi]", I constructed my program, but it is not working.
If I don't put the trigger and the Start Task, my program run without any problem (in this case I'm using 4 DAQmx Create Channel AI Voltage, one DAQ Timing, that is linked to the DAQmx Read which is on the loop). But when I add the trigger (Start Analog Edge) out of the Loop and between the DAQmx Timing and the DAQmx Read, the error -200077 apears. This same error apears too when I try to run the example "Cont Acq&Graph Voltage" (even if I change the sample rate and the number of samples, the error is still the same). The error -200431 apears when I try to run the second example ("Impact Test(DAQmx) [SVXMPL_Impact Test(DAQmx).vi]), but in this case probably the DAQ card is not adapted to run this program.
When I add an start task before the Loop (where DAQmx Read function is localized) on my program without the trigger, the error -200278 appears. And if I add the trigger and the Start Task function, just the -200077 error apperas. However, the Start Task isn't bothering me as much as the trigger, because when I don't use the Trigger on the example "Cont Acq&Graph Voltage", and the Start task is still there, this program runs normally. So probably in this case the problem is on my prgram and not on my DAQ card.
I just would like to know if my card can't run this trigger (Start Analog Edge) function or if there is something else, because it's strange how a relatively simple example can't be run using my DAQ card.
Thank you
(3,338 Views)
Accepted by FCB
Hi FCB,
The USB 6211 can only be triggered digitally.
The document attached allows you to see the specifications of your card:
https://www.ni.com/en-us/support/model.usb-6211.html
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(3,320 Views)
Thank you very much !!
(3,310 Views)
