DAQmx (USB6210, C interface) gated edge count problem
Our application needs to
(1) provide a gating pulse for an external device
(2) to monitor the number of pulses returned from that device when gated.
We want to use the USB6210 using the DAQmx C functions for that.
So, I set up the gating pulse. That works. The output looks good on a scope.
- DAQmxCreateTask
- DAQmxCreateCOPulseChanFreq using ctr0
- DAQmxCfgImplicitTiming
- DAQmxStartTask
I also set up ctr1 for Edge Counting
- DAQmxCreateTask
- DAQmxCreateCIcountEdgesChan using ctr1
Now, I think I have to route the output of the gating pulse to the gate of ctr1.
The manual says that should be possible (8-27)
However, DAQmxExportSignal to ctr1gate leads to an error:
Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
Property: DAQmx_CI_PulseWidth_Term
Property: DAQmx_CI_PulseWidth_StartingEdge
Source Device: Dev1
Source Terminal: PFI2
Required Resources in Use by
Task Name: gatingpuls
Source Device: Dev1
Source Terminal: Ctr0InternalOutput
Destination Device: Dev1
Destination Terminal: Ctr1Gate
Task Name: pulszaehler
Status Code: -89137
DAQmxConnectTerms doesn't help either:
Property: DAQmx_CI_CtrTimebaseActiveEdge
Source Device: Dev1
Source Terminal: 80MHzTimebase
Destination Terminal: Ctr1Source
Source Device: Dev1
Source Terminal: PFI3
Status Code: -89137
I thought of wiring the output to the PFI where the gate is but that gives me the problem how to define the gating input PFI for ctr1.
Which functions shall I use to obtain the desired functionality?
Niels
(3,363 Views)
Hi Niels,
i can imagine that the error comes because your device not support these feature. See followings links:
http://digital.ni.com/public.nsf/allkb/B3A73388A3968E0F86257156007F7E3E?OpenDocument
http://digital.ni.com/public.nsf/allkb/A7A4024278353BF7862570230072C6E1?OpenDocument
Attached here a file with screenshot about possible device routes. You can test a simulated pci 6210 - when the error comes not than not for usb.
As workaround you can give a signal to a pin (output) and read it on an other pin as input as trigger source - the manual of device (pin assignments)
tell you what pfi line is what pinnumber. Hope this helps
Best Regards
Johann
(3,348 Views)
Hi Johann,
thanks, that sounds as if it could do the trick. I will try to wire the ctr0 output to the ctr1 gate and then I'll find out how to switch on external gating.
Best regards
Niels
(3,341 Views)
