DAQmx analog read with offest
In the test I am trying to setup, I need to record load readings with the initial load taken out.  I take the initial reading and then subtract that from all following readings. Say I have an initial load of 50lbs, I want all readings taken during the test to offset by 50lbs.
Currently I take a reading before entering the acquisition loop and subtract the inital reading from all new readings before recording the data. What I would like to do, is somehow tell DAQmx to do the offset for me. Is that possible? and if so how whould I do that?
Ryan Podsim, CLA
(2,859 Views)
Accepted by rpodsim
Hi Ryan,
You can use the following function:
int32 DAQmxCreateLinScale (const char name[], float64 slope, float64 yIntercept, int32 preScaledUnits, const char scaledUnits[])
If you create a scale in the above way, you must modify your CreateAI...Chan function. Replace "units" parameter to "DAQmx_Val_FromCustomScale" and set "customScaleName" to name that you specify in the DAQmxCreateLinScale function.
You can find detailed info in the ni-daqmx c reference help!
Greets,
- George -
(2,850 Views)
